Anyone got a clean pinout for the Milwaukee M12 battery?
Been digging around to find a solid reference for the pinout of the M12 packs. From what I can find online, it's C1- to negative, C3+ as the positive, the T line go to a thermistor to monitor the temperature of the pack, and C1+ and C2+ are the balance pins for each cell group.
Given the number of cells in the pack, it makes sense that these balance pins would be along each group of cells. It seems like there's some debate about whether the charger or the pack itself performs the balancing function, though. I haven't scoped the thermistor on any Milwaukee M12 packs yet to find the value of the thermistor that they use. Does the tool check the thermistor on the pack itself? Also, are the balance pins always live, or only if there's a pack docked to the tool? Has anyone rebuilt any of these packs? If so, did they have to take any special steps to reattach the balance leads? There doesnt seem to be much documentation on how these M12 packs work outside of the tool's documentation, so figured it was worth a thread.
scoped out the thermistor on a gen 2 pack, its a 10k NTC. Tool checks it, fried thermistor line on one pack and tool would not spin up despite fine voltage reading.
wait so if the charger does the balancing what happens if I only run the pack on the tool and never charge it past 80%?
basically yes. That's why people get one weak cell group on their M12s because the charger never balances the cells if they're never charged to 100%. You have to use them flat to full once in a while to balance them out.
your pinout is right. The charger does balancing not the pack, the M12 packs are dumb, no real BMS just protection.
You have to include in that there is a small BMS on the pack that cuts out if the cells are over discharged or overvoltage during charging. It's not for balancing but the "dumb" of the M12s undersells it. The taps go to the BMS itself. There is no balancing done on the tool, it just read the cells voltage to report to the user.
rebuild a 4ah m12 last summer. Pulled three samsung 18650s out and replaced with three fresh new ones. Kept the original pcb on the pack. M12 came back fine but had to charge to 100% for the charger to stop blinking red on me. Did some spot welding on the balance leads and got them back to their original tabs on the PCB.
rebuild a 4ah m12 last summer. Pulled three samsung 18650s out and replaced with three fresh new ones. Kept the original pcb on the pack. M12 came back fine but had to charge to 100% for the charger to stop blinking red on me. Did some spot welding on the balance leads and got th…
interesting so if I were to do a pack rebuild with fresh cells would the Milwaukee charger just sort out the cells on its own or would I have to get them all to the same voltage with a hobby charger first?
bring them to the same voltage first. Milwaukee chargers will not compensate for significant difference in voltage between cells. It will throw a fault and refuse to charge. Charge each group to 3.7v with my imax b6 before reassembly.
C3+ is positive can be tricky to find people used to other brands. C1,C2,C3 are the three groups of cells and + indicates which side of the cell group the balance lead is on.
To answer your other question, the C1+ and C2+ pins are live all the time. They just go to the cell junctions directly through the BMS on the pack.
You can stick a meter on them anytime the pack has charge.
has anyone tried wiring an external balance connector onto one of these so you can plug it into a hobby charger directly? thinking about it for my dead pile
yeah ive done it on two packs. Soldered a jst-xh to the pcb tap points, works fine. Just remember the order, very easy to reverse it and pop something.
NTC is 10k like someone said above, beta around 3380 if you care. Measured it on three different m12 packs and got the same curve every time so it's consistent across at least the gen 2 and gen 3 stuff i had on hand.
Worth adding that on the newer high output M12 packs (the ones with the LED fuel gauge) there's a slightly different PCB and the comms are a bit more involved. Not full smbus or anything but the charger does seem to read more than just the voltage taps. Haven't fully traced it.
waitthes different generations with different boards? how do i tell which one i have without cracking it open
The easiest way is to look at the fuel gauge button on the side of the pack. No button means it's an older-style protection-only board. If there's a button with LEDs on it, that's the newer board with the fuel gauge IC and more logic. There is also a date code on the label on the pack, if it's 2018 or newer it's likely the newer board.
