Crockpot won't heat anymore, is it usually the heating band?
Saw a few individuals asking about Crockpot issues with the pots stopping heating. Usually the heating band is the issue. Thought I’d bring this up for discussion as this seems to be the topic of most discussions regarding kitchen appliances instead of the much more common coffee makers and kettles.
According to the posts, you can access the heating band from under the bottom cover of the crockpot. Some special rivets secure the bottom cover to the crockpot that you must drill out to allow access to the heating band. Once you locate the heating band, it appears that if it’s the problem, you have to replace the entire heating band assembly as one piece. This is because the band and the crockpot is essentially one piece; the heating band is the heating element itself that is bonded to the crockpot.
However, one thing that seems to be of interest to most individuals is whether or not these heating bands are available as an individual component that can be purchased for these crockpots. Furthermore, can you acquire these bands in general from the hardware stores? Wouldn’t it be cheaper to just buy a new crockpot rather than sourcing these bands?
9 times out of 10 yeah its the band. But before you start drilling rivets out check the thermal fuse and the switch first, ive seen plenty come back from the dead just from a busted switch.
honestly for what a new crockpot costs at walmart i wouldnt even bother. Like $25 for a basic one. Spend two hours drilling rivets to save $5? nah
Do the bands actually fail open or do they go to ground? curious what the typical failure mode is on these. I’d think that the element wire would break, but maybe the insulation on the element fails?
sourced one once for an older Rival. Had to buy a donor unit off ebay because nobody stocks the bands as a separate part. Ended up being more work than it was worth tbh
The bands are absolutely NOT universal. Different wattages, different diameters, different lead lengths. You’ll need the exact model or a very close sibling model from the same manufacturer year. People who tell you otherwise has never actually done one.
see this is what i mean. Youd have to be insane to chase this down
i fixed my moms last year. It wasnt the band at all it was the little rotary switch on the front, contacts were burnt to hell. Cleaned em up with some emery cloth and its been running 8 months.
what wattage was it? im wondering if the higher wattage crockpots burn out the switch contacts faster?
lol at everyone saying just buy a new one. Some of us actually like fixing stuff thats the whole point of this sub
it was a 240w hamilton beach i think. Nothing crazy. But the contacts were beat up from being arced to the point they started to burn spots on the contacts.
My grandma had a Rival from like 1978 that finally died two years ago. I took it apart and found the band to be PERFECT. No breaks at all. The wire to the crockpot itself was broken though at the point where it enters the strain relief. That only costs $5 to fix, though. If you find an issue with any appliance, test the easy fixes first.
how do you test the band without taking the whole crockpot apart? can you test the resistance at the cord end?
You can. Once you have the bottom cover off (again, have to drill the rivets out), put the meter leads across the leads from the heating band. You should see somewhere in the 40-80 ohm range depending on the wattage setting. If you have an open circuit the heating band is the issue.
i had a cuisinart slow cooker do this and the issue was the temperature control board not the band. The newer slow cookers with electronic settings have more points of failure than the older machines with knobs to control temperature.
