jura users always gotta bring up jura
i mean its true tho
Another instance when the brew group got jammed and would not budge. The only thing that worked was to open the machine up and manually rotate the brew group back to its home position. It was tight on the side gears so I had to use the socket wrench to rotate. Took about 20 minut…
wait can you manually rotate the brew group drive shaft with a socket wrench? what size?
7mm iirc, but double check on your machine model. Also ensure you dont force it if you feel resistance in the brew group as you may strip the plastic gears.
