What do the auto menu numbers on Panasonic microwaves actually map to?
While I was looking up the Panasonic auto menu presets I saw a chart floating around so figured it was worth a discussion as many peoples dont have the booklet to refer to. Each number is a preset cooking program and the time is calculate from the program and the weight of the food you enter into the microwave.
The list of these programs is as follows: 1 Auto Reheat, 2 Reheat Fried Rice, 3 Congee/Porridge, 4 Instant Noodles, 5 Double Boil, 6 Vegetables, 7 Potatoes, 8 Fish, 9 Chicken, 10 Casserole Rice. So it isnt power levels like many people might assume but rather food categories. For instance, if you press the Chicken button and enter the weight 400g the microwave will heat the chicken for around 5 minute.
The internal workings of the weight settings is based upon a lookup table for each of these programs. For instance, steaming a 400g fish is not the same as cooking 400g of chicken so the time needed for each would not be the same. A sensor on some of the higher end Panasonic microwaves will override the weight input.
The weight input is an estimate. The sensor detects steam and recalculate the time needed for the food to cook to a proper temperature. The cheaper models without the sensor just use the weight input to determine the time needed.
Upon finding the manual for the NN model the presets are stored in a lookup table in the firmware. Each preset has its own time, power and weight setting. The table is not linear; 200 and 300g would take the same amount of time but 400g would take longer. The older models didnt have any of this and these programs started in the late 1990s with the introduction of the inverter microwave. The regional settings are different though. For example, the Asian models has settings for congee and rice and the European models have items like jacket potato instead.
I dont think you have to overthink it to much. It’s a preset so when you press the number and enter the weight the food comes out heated.
